I'm trying to burn a mpeg file with EZ Creator and it says my mpeg's video bitrate is not acceptable. It also said my audio bitrate is 'probably OK'. The video bitrate is 1246kb/s and the audio is 128kb/s. What do I need to do to fix it so I can burn it? Thanks in advance guys.
EZ CD Creator does not support non-standard VCD's, you must use the standard 1150kbps for Video and 224k for Audio, or switch to a GOOD program, like Nero, or basicly ANYTHING else.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
So should I find a program to fix the bitrates or not bother and just burn it with Nero just the way it is? If I don't make any changes and burn with Nero, will my VCD player play it?
You can only Re-Encode the files to make them Standard, and that will produce lower quality files, but it's your only choice if youwant to use EZ CD.
Or you could use Nero, and disable to Compliancy Check, and it will be able to accept your files.
Best Regards,
Sefy Levy,
Video compression error: The source image format is not acceptable
By jh443 in forum Video ConversionReplies: 8Last Post: 25th Apr 2011, 21:56 -
video compression error: The source image format is not acceptable.
By cutepraba in forum Video ConversionReplies: 0Last Post: 12th Dec 2010, 10:21 -
Is this VHS Quality Acceptable?
By cfelicio in forum RestorationReplies: 34Last Post: 5th Dec 2010, 13:22 -
How much wind acceptable?
By B-Twien Bytes in forum AudioReplies: 5Last Post: 1st Feb 2010, 17:44 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34
