My friend had windows 98 and then installed XP and since the drivers didnt work he tried installing 98 but now nothing worked, i tried helping him tried installing the 98 CD and also the XP CD and nothing, for the windows 98 CD it boots up but when it comes to formatting it wont start, and for the XP cd it says "booting from CD: " but the setup never starts
anybody got any ideas to help my friend?
Once you upgrade to XP, you can't go back without a format and fresh install, as you have discovered. When he set up 98, did he create the recommended rescue disk on floppy ? If so, try booting off it instead, and using the fdisk command. If you don't have one, you could try here http://www.bootdisk.com/
thanx a lot i think ima try that boot disk, i tried fdisk but didnt work
This could be fun to try too, free, a complete windows environment on a dvd:
Bart's Preinstalled Environment (BartPE) bootable live windows CD/DVD
http://www.nu2.nu/pebuilder/ -
I had to put my drive as non-boot in existing xp system and from admin tools delete all the partitions
i was wondering is it possible for me to format the hard drive in another computer as fat32 and then move it back to the pc i want to install windows 98 on, would that be possible? or buying a new hard drive and installing? would that work?
Installing XP on a used PC
By CSULB71 in forum ComputerReplies: 24Last Post: 21st Nov 2008, 11:05 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 20:03 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
installing
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 4th Mar 2008, 07:13 -
installing Binaries
By mahanpots in forum ffmpegX general discussionReplies: 1Last Post: 14th Dec 2007, 10:16
