is it possible to record you singing to a song through your mic and playing a song through musicmatch at the same time through sound recorder?
As long as your soundcard supports multiple audio streams, I don't see why not, tho you'd be better off with some better recording software, try Audacity. It's free and is a drastic improvement over what you're using.
You are in breach of the forum rules and are being banned.
/ Moderator John Q. Publik
RAW MiniDV recorder software for Windows
By eadmaster in forum Capturing and VCRReplies: 1Last Post: 8th May 2011, 02:22 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 20:23 -
Capturing Audio in Sound Recorder
By ViRaL1 in forum Off topicReplies: 3Last Post: 2nd Dec 2008, 03:26 -
windows mp is not playing sound on videos (but only on one windows account)
By lightsout85 in forum Software PlayingReplies: 0Last Post: 30th Jul 2007, 16:19
