I wasn't very clear with my subject, let me explain.
My friend sent me a Japanse Anime DVD over the internet. When it downloaded it became a "Video_TS" folder. He told me to add it to Nero Vision Express and it would burn. It did indeed burn and played on my computer.
When I took the DVD to my TV DVd Player (SONY DVP-S5360) It said it was prohbited from playing. I tried playing it on a cheapo JWin and it played just fine.
How can I Edit the Video_TS files so that it'll be region unlocked.
Oh and have some mercy regarding the legality of this post. I'm not "advocating Piracy". I just wanna know If this can be done.
My friend says to burn the movie on DVD and then use DVD Shrink to remove the region lock. Is there a better way than this?
Thanks for all your help.
You don't need to burn it first. Load the DVD into Shrink using Open Files, then hit backup and send to a HDD folder. You will get the region options when you hit Backup. You might also be able to do it with IFOEdit or similar.
It might also say Prohibited if it is the wrong format. Is the DVD PAL ?Read my blog here.
Originally Posted by Trilobyte
PAL to NTSC conversion is a long, time consuming task, unless you want to capture it from the player you have that will play it to transfer it.
And the cheapo dvd player's alot of time's will convert PAL to NTSC, go figure.
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 04:34 -
Can't remove region restriction using DVD Shrink. Work-arounds?
By csloane@nwnexus.com in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2008, 16:04 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 13:39 -
removing CSS from a video_ts folder?
By ehmjay in forum MacReplies: 23Last Post: 29th Feb 2008, 20:15 -
No Video_TS Folder..
By NatalieR in forum ffmpegX general discussionReplies: 1Last Post: 5th Feb 2008, 10:53
