  1. Hi all,
    Is it possible to have DVD style menus( the ones having running clips as menu choices) on a VCD. If yes, what tools are needed for that and how are they used to create such menus ? Please help
    Thanks,
    Anil
  2. TSCV http://www.personal.psu.edu/users/r/d/rdm186/
    You can d/load the newest ver from http://www.doom9.org
    It's a VERY nice program. I've made several motion menus, intros, etc. w/ it. Suggest burning bin/cue files with either VCDEasy/XDuplicator which are both GUIs for CDRDAO. Can also down load at doom9. DO NOT try to burn bin/cue w/ Nero! Can also use Fireburner or CDRWin but they cost money
  3. Thanks a lot Vejita-sama !! On seeing the guide,you gave a link to, I was sure that I could not succeed but when I followed it step by step I could not believe my eyes. I had what I wanted for so many days - a motion menu with nine clips running in separate windows at the same time. Although, I did not understand what I did, I simply followed the guide. Can you please give me link where I can get some insight into frame serving & VFAPI ? The rest of it was clear.
    Thanks once again. Its for helpful guys like you that I come here everyday. Someday, may be, I will also be smart enough to help others like me.
    Bye,
    Anil
