Hi guys.
I recently split a movie into 2 using DVD Fab 0.17 (the freeware version), and it output the files into separate Audio TS and Video TS.
So, how do I burn it? Will Decrypter do the trick?
Thx!
MJ
(1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
(2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
GET MCSE HERE
BenQ Ownz j00 -
Load your burning software (Nero, CopytoDVD etc) and select DVD Video. Bring in these two directories and burn. DVD Decryptor requires an ISO file to burn. An ISO file is a form of disk image used by some burning programs. Someone else here may be able to give you an easy way to turn your folders into an ISO.
Read my blog here.
GET MCSE HERE
BenQ Ownz j00 -
Image tool classic should work.
http://www.coujo.de/ib2/index.php?act=module&module=include&incl_name=download -
Thanks mate.
I'll give it a try.
- MJ(1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
GET MCSE HERE
BenQ Ownz j00 -
GET MCSE HERE
BenQ Ownz j00
Made On Demand discs - bad burns
By oldfart13 in forum DVD RippingReplies: 5Last Post: 12th Aug 2011, 14:45 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
DVDFab HD not reading discs.....
By E_Merlin in forum DVD RippingReplies: 19Last Post: 19th Jan 2008, 22:40 -
Are Verbatim's 'Made in Taiwan' discs...
By dvdashot in forum MediaReplies: 2Last Post: 8th Aug 2007, 14:55 -
dvdfab platinum has made many chinese students happy
By jimdagys in forum DVD RippingReplies: 0Last Post: 1st Jun 2007, 08:06
