I create DVD video files using TMPG Express and TMPG Author. Initially the files are fine but later when I play them back using WinDVD the movie somehow has been combined with other movies on the hard drive. In other words I see parts of at least two movie when I should only see one. Does anyone know what is causing this?
In what way are they combined ? Files don't just leak into each other because they were stored too close together on the nard drive. It is either something you are doing when you encode or author, or something winDVD is doing on playback. A better decsription of the actual problem would help us determine where the problem lies. Are they mixed as in a cross fade type effect, or more like they have been cut together ?
Read my blog here.
HDD fragmentation can cause this. So can IDE driver failure/error/corruption.
Thanks everyone, the problem also occurs if I burn the movie. It like the movies have been cut together. I will defrag more often. I will also check for new IDE drivers for my motherboard and IDE controller card. Thanks again
Program to repair corrupt video files
By adrien23 in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2011, 19:32 -
Corrupt MP4 and FLV Files - VLC Plays different Video
By ColdCoffee in forum Software PlayingReplies: 2Last Post: 25th Apr 2010, 09:32 -
Help with Corrupt mp4 video files. from Sanyo WH-1
By Jmiller0921 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 31st Mar 2010, 23:27 -
Corrupt Video Files on hard disk
By gooberguy in forum EditingReplies: 1Last Post: 26th Mar 2010, 02:55 -
Corrupt Video Files - Doomsday Arrived
By Quarkrad in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 11:15
