  1. I want to join three mpegs into one to burn onto a vcd. But whenever I try to join them using TPMG it says they aren't compatible with each other. Does anyone know why I get this error?
    Mike
  2. I also got the same error when I used Sefy's SeVCD (PAL) template in TMPGENC to convert my AVIs to MPGs and then tried to join them using MPEG tools.
    I got a workaround by re-encoding my AVIs to MPGs using the VideoCD template and then the mpeg tools didn't complain.
    Hope this will help.
    Anil
  3. dmikester1, all files must be of same specs before you can join them up together, re-encoding is a good option, but reduces the quality of the files.
    aktayal33, my SeVCD is hardly a standard, you could use the MPEG Tools in TMPGEnc and select a Non-Standard VIdeoCD
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
