Have extracted the WAV from an avi file with virtualdub and converted to Ac3 with Sonic Foundry Soft Encode. After re authoring to dvd, when i play it with PowerDVD it shows up as 5.0 audio instead of 5.1. I have read in the forum that you have to input 6 mono WAVS into Sonic Foundry to get 5.1 audio, and i am convinced i am using the right settings in Sonic Foundry too therefore i believe i am doing something wrong with the WAV extraction and not inputting the correct WAV or WAVS into Sonic Foundry. Any help would be greatly appreciated.
Not everything reads the files correctly. Virtualdub may report all multichannel AC3s as 5.1. Soft Encode is (old and slow) pretty good at what it does, so if the LFE isn't in the output, chances are it wasn't in the input.
When you opened the wav file, did you specify 6 channels or only 5 ?Read my blog here.
In virtualdub when you save the WAV file where do you specify either 5 or 6 channels?
When i import WAV file as Microsoft PCM i do not see this option, but when i import WAV as raw data i do. I now have all 6 channels in Soft Encode but the track length should be 1 hour 43 mins but they are only showing 34 mins, which is strange. When i import as Microsoft PCM the track length is correct but only 2 channels are present. Any ideas guns1inger? Your patience is very much appreciated.
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
how to transcode from AC3 to WAV
By phpmysql348 in forum AudioReplies: 3Last Post: 7th Sep 2008, 00:46 -
how can we convert ac3 to wav?
By sumeshkri in forum AudioReplies: 6Last Post: 4th Sep 2008, 02:29 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:44 -
AC3 to WAV (MUST KEEP 6 CHANNELS)
By RushMaster in forum AudioReplies: 6Last Post: 17th Oct 2007, 04:03
