If the original file has a 352X240 and 1500kbps and if I am to accept Nero default settings (Quality=Automatic), the end result would be Super Long Play (352X240 1693 kbps), however If I am to set the Quality to Standard Play, the end result would be 720X480 and 5073 kbps. Would the setting to Standard Play improves the quality of the DVD playing on standalone DVD player or should I just leave everything to Nero? (as I was told if I blown up the original from 352X240 to 720X480, it would actually makes the video quality worst!?), also how can you tell the quality of a downloaded avi/mpeg file before burning to DVD disc?
OK, I know before burning to DVD disc the file will be in Video_TS, and if I have several Video_TS files at different folders, is it possible to combine them and burn them to the same disc? (or it doesn't work this way?) one last thing, is the Recode program ONLY deals with Video_TS folder/files?
Thanks for your help/feedback in advance.
1) No...upsizing the res will not do ANYTHING positive (form an mpeg source)..east of all increase quality....in fact the oposite is true.
2)Yes..you can author as many vids onto a DVD as may fit (dictated by the bitrates)..use TDA...open DVD files if using VOBS as your source.
3) Walk away from NERO..and get some better tools. TMPG+ (for encoding) and TDA (tmpg DVD Author) are a good start.No2: We want Information.
No6: You wont get it! -
Thanks monzie for the quick reply, will stick to default from now on. :P
VIDEO_TS to DVD best free software for picture quality
By gary153 in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2010, 18:19 -
VIDEO_TS 7GB to VIDEO_TS 4GB
By klemyz in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2009, 12:43 -
VIDEO_TS to AVI and (maybe) back to VIDEO_TS
By macbuz in forum MacReplies: 2Last Post: 16th Jan 2009, 19:40 -
VIDEO_TS to mpg to VIDEO_TS
By Mållgan in forum EditingReplies: 9Last Post: 29th Jan 2008, 14:53 -
Video_TS to Divx. super poor quality after encoding
By mistervolcom88 in forum MacReplies: 5Last Post: 13th Sep 2007, 13:49
