I am a complete novice at doing video capture, so please bear with me...
I am getting intermittant pops and a slight hum on my audio track when
doing VHS captures with my computer. Here's my set-up:
Panasonic AG-1980 VCR
Canopus MVR-1000 capture card
Athlon 1900 XP, K7S5A, 1 GB, Win2K
Physical set up is: VCR next to computer next to monitor
I'm using the S-video ports for the video, and RCA jacks for the audio.
The S-video cable is a very high-quality shielded cable, but there's nothing
special about the RCA cable pair.
Does anyone have any ideas on what the problem is? Will better RCA
cables solve the problem, or is there just too much electrical
interference inside (or outside) my computer?
Thanks,
vobnovice
Can you try a differnet vcr? I know the Panasonic is a good one but perhaps it's aged and needs a tune up?
I had a VCR that was missing the "metal" plugs for the audio.
I had once used gold plated RCA stereo cords that fit VERY tight and when I pulled them out they pulled out the "metal" plug!
I used different cables and it seemed to work when attached to my stereo but when I tried to capture to my computer with that VCR I would get a very annoying loud humming noise.
The solution for me was to just use another VCR with metal plugs in place as they should be hehehe
Audio hum during video capture...help.
By daysaf00 in forum Capturing and VCRReplies: 16Last Post: 27th Jan 2012, 21:04 -
Need help with low level hum (audio attached)
By sdsumike619 in forum AudioReplies: 10Last Post: 22nd Aug 2010, 03:34 -
Ticks and Pops in Audio
By punkyb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Jun 2009, 16:29 -
Pinnacle Studios 11 - Low Frequency Audio Hum
By notheldge in forum Capturing and VCRReplies: 9Last Post: 15th Aug 2008, 13:07 -
Ground Loop problem. Subwoofer hum. Will this gound isolater work on HD
By Denvers Dawgs in forum DVB / IPTVReplies: 3Last Post: 17th Jun 2007, 00:43
