I have recently bought Adobe Encore 1.5 and spent hours creating a simple but useful DVD menu for some film work that I have done. On the preview the menu works fine and does everythign it should, however, when I build and burn the disc and put it into a DVD player - nothing!
Neither of the Buttons on the opening menu are highlighted or can be highlighted. I have made sure that I have a default button selected and button routing is fine. Please help me as I have wasted time and money attempting to produce a DVD and so far all my attempts have failed.
Don't know if this will help you but it has helprd me.
go here and d/l video tutorials http://www.wrigleyvideo.com/videotutorial/ -
Encore has a check function under <file>. It will check the structure to see if you have everything in order. Another thing to check is to see if the said DVD plays from the HD. If it works on the HD then the issue may be in the media and/or the DVD player.
For me I always write my DVD to the HD and then add a AUDIO_TS folder and burn to disc with my favorite burn software.
_ -
Personally, I burn the disc right from encore and it works fine every time, BUT first I usually choose File-->make dvd folder. and have encore create a folder on the hard drive (including the videots file structure) and open that folder in my powerdve to make sure everything functions as it should. this is cheaper than wasting a dvd-r on some simple mistake on a menu. if it does play fine, then you can burn that veideo_ts folder with burning software or just create the "dvd-disc" from encore (which is what I do). If it plays fine off of hard drive and not in set top, then youve got media issue or dvd player issue. try burning at 1x. Also, be sure to check the project like the previous poster said...this is quick and easy to make sure button's are set up and there are no dead links.
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 07:30 -
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 20:24 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
