I have a Leadtek TV2000XP TV card. I want to use it to record World Rally Car events. I've been reading tons of stuff here and doing lots of test captures.
When capturing to uncompressed AVI I'm getting fringy looking horizontal lines along vertical edges and on anything fast moving. Also jaggies on diagonal edges. Makes things look fuzzy.
I've tried the TV2000's software both with no codec and with Huffy, and virtualvcr with Huffy (both YUY2 and RGB24) and get the same results. When I record with the TV2000's MPEG2 setting, the picture is normal.
I plan to edit out the commercials and author these to DVD with menus later. Is this going to show up in the final output?
You may be seeing interlacing. Try convert your avi captures to mpeg2 and look at them.
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
VirtualDub Filter for problem with "Horizontal Sync Issues"?
By lonerzzz in forum RestorationReplies: 6Last Post: 6th Apr 2009, 18:29 -
leadtek PxDVR3200 H - HD component input
By Thalandor in forum Capturing and VCRReplies: 1Last Post: 30th Oct 2008, 21:10 -
sony dcr-trv740 tape 'horizontal block shift' problem
By david101 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Sep 2008, 23:42 -
What is better than a leadtek expert tv tuner card?
By Gplracer in forum Capturing and VCRReplies: 1Last Post: 7th Jul 2007, 14:44
