Results 1 to 16 of 16
  1. If enywone can help me .... Have this Stand Alone Player
    Samsung DVD-P245 ,the only problemis ..cannot read subtitles whith some charachter like this .... î â Â Î (see the Image below). The charactersare for the Romanian Language. By the Samsung.com the "Update Firmware" is the same version whit that hwo is in DVD Player . Have mail to the Samsung...nobody answere.
    If enywone could help me...please
    koko
  2. try to mux the subs into the file with fuse
    you can get it here
    http://labs.divx.com/
    let me know if it works
    thekid...
  3. thedivxkid......
    how ? is a software or some like that ? dont understand
    koko
  4. yes fuse is a software tool
    download it from labs and read the how to guide that comes with it
    its very easy
    thekid...
    Mar 2004
    Lisbon
    Fuse is a command line tool and it wont work with Xvid.
  6. fuse is a command line too and it WILL work with XviD.
    get the latest version
    thekid...
    Mar 2004
    Lisbon
    I have the latest version of Fuse. Maybe i am doing something wrong.
  8. what error message are you getting? or what is happening when you try?
    thekid...
    Mar 2004
    Lisbon
    Hi thedivxkid, this is the error message that I got:
    fuse -v saw.avi -s saw.srt -o saw.divx
    option --vidfile[0] = >saw.avi<
    option --subfile[0] = >saw.srt<
    option --outfile = >saw.divx<
    option --infile = >saw.avi<
    option --profile = >HD<
    Processing beginning chunks.
    Processing all chunks.
    VBV TEST PASSED
    0 Multiple B_VOPS Detected
    1 MPEG-4 B VOP: chunk packing incorrect.
    Result: FAIL
    WARNING: Files encoded with, GMC, Qpel, MPEG Quantization, Multiple B-frames or
    files that exceed the VBV limitations will not playback properly on DivX Certifi
    ed hardware devices. Make sure you select the proper DivX profile within the Xv
    iD codec during encoding to ensure proper playback and interoperability on hardw
    are. Files with these features may not be written or playback properly.
    Unable to open file : C:\DOCUME~1\PAULOM~1.P4\LOCALS~1\Temp\saw.xsub
    Unable to open file : C:\DOCUME~1\PAULOM~1.P4\LOCALS~1\Temp\saw.xsubexce ption ca
    ught from : createDivXMediaFile
    Can you help me?
    Regards,
    magnop
    Aug 2003
    You mention Qpel under the warning. I have the Philips dvp642 and it doesn't like a file encoded with Qpel. Just a thought.
    Mar 2004
    Lisbon
    This is a generic warning from Fuse. I checked the avi info and it is not Qpel, GMC or Packed Bitstream.
  12. right before it failed it shows what failed
    are you using more than 1 b-frame? If so how many? I think too many can cause this problem.
    the message below that is generic to cover most of the things that could cause it to fail or not playback properly on hardware.
    thekid...
    Mar 2004
    Lisbon
    thekid...
    How can I check the number of b-frames?
  14. that is an excellent question
    i think there is a tool called MP4modifier or something liket that, that can tell you. I think GSPOT only tells you if they are used, but not the number of them used.
    thekid...
    Mar 2004
    Lisbon
    Hi again,
    Can't get the info from GSpot.
    MPEG4 Modifier shows this info:
    Packed bitstream: No
    QPel: No
    GMC: No
    Interlaced: No
    Aspect ratio: Square pixels
    Quant type: H.263
    I-VOPs: 1156 (1,56%)
    P-VOPs: 28321 (38,26%)
    B-VOPs: 44553 (60,18%)
    S-VOPs: 0 (0,00%)
    N-VOPs: 0 (0,00%)
    Max consecutive B-VOPs: 2
    1 consec: 33,29%
    2 consec: 66,71%
    Are b-frames the B-VOPs?
  16. yes
    and i thought it could work with a max of 2, let me double check and get back to you
    thekid...
