    Feb 2005
    I have a 3.2 GHz processor with 1 MB cache 800 MHz FBS. Is 7h 25min 25sec a long time to encode a 2h17m20s movie using TMPGEnc or that about normal?
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    What are the exact setting that you have applied to the encode? Adding more settings beyond the default can extend it along time. For reference, a 2 hour encode on my P4 2.4/533/1GB333/120GBSATA takes just over 4 hours to encode single pass anamorphic frameserved from VDUB, double that for a 2-pass VBR.
    You are in breach of the forum rules and are being banned.
    / Moderator John Q. Publik
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Ideally, if you could post the settings of all tabs here, we might be able to give you some specific pointers.
    Without that, there are a number of guides in the guides section with some good tips, particularly one entitled "Configuring TMPGEnc for MPEG-2 quality AND speed" or something similar. I think Lordsmurf also has a configuration guide at www.digitalfaq.com that can assist you with this.
    Off the top though, and in no particular order:
    - 2-pass VBR will take twice as long as CBR
    - Setting Search Precision to Motion Search (fast)
    - Setting program priorities to high
    - Not using computer for other tasks while it encodes
    - having source on one hard drive and outputting to another
    - inbuilt TMPGEnc filters take waaaay too long. Try using AVISynth scripts and/or frameserving from virtualdub if you need filters.
    This should get you started.
    If in doubt, Google it.
    Apr 2004
    Miskatonic U
    And if you add tmgenc filters you can take a major speed hit.
    Mr. Troll - just how do you work with a 12GB hard drive ?
    Read my blog here.
  5. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    My bad....should read 120 Gb.
    Feb 2005
    I was using this guide here. I'm not sure exactly how to do screenshots and stuff. Just follow this guide and thats what I did. I hope this helps. https://www.videohelp.com/forum/userguides/186739.php
    My movie was 23.976 FPS so I used the settings in the guide that go along with that. Also, before using TMPGEnc, I had two avi files that I joined together using virtual hub, I'm not sure if this makes a difference or not.
