Hi
I need a good software for correcting a sync problems in mpeg2 files.
S
That only works some of the time. If the error is ALL OVER the file, nothing can fix that, except something that fixes PTS (pvastrumento, for example).
Audio sync is often the result of dropped video frames.Want my help? Ask here! (not via PM!)
If you are out by a constant amount, i.e. the audio comes in 3 seconds late and stays there for the duration, then there are a couple of tools to look at. The simplest is to demux the audio and chop or add a few seconds off the begining. This is easier in an editor that can show the video along side it. Sound Forge might be able to do it, or a good video editor like Vegas. Once it is lined up, output just the audio and remux. This way you don't reencode the video.
Read my blog here.
I have used mp3directcut to clip the audio after I demux, but I first have to determine how far out of sync the clip is. I use vdubmpeg2 for that. mp3directcut is fast because it does not re-encode the audio.
Any product similar to the AV Toolbox AP-411 lip-sync corrector?
By svejkovat in forum AudioReplies: 3Last Post: 5th Feb 2012, 12:29 -
TBC or video corrector
By mark23 in forum RestorationReplies: 7Last Post: 16th Mar 2011, 05:50 -
Color Corrector
By cynikalhedonist in forum EditingReplies: 8Last Post: 25th Jun 2010, 12:49 -
Hardware corrector or Software
By mark23 in forum RestorationReplies: 4Last Post: 11th May 2010, 03:43 -
Do I need a Time Base Corrector? If so, which do I get?
By Smack2k in forum Capturing and VCRReplies: 3Last Post: 11th Jul 2008, 10:41
