  1. if i have a PAL dvd and i play it on a NTSC dvd player will it be black and white? is so can u patch PAL dvds so it has color?
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    My ntsc player will play a pal disk just fine but not all of them will. You cannot patch just the colour, you must do a proper conversion which means changing the framerate and the audio duration. Check out this.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You could try the header patch trick, which supposedly works from PAL -> NTSC or NTSC -> PAL, but generally, you are better off buying a cheap mutli-format player.
  4. Originally Posted by guns1inger
    on SOME DVD players it should be noted. By doing this your are breaking DVD standards compliancy
    There are 10 kinds of people in this world. Those that understand binary...
  5. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    my older Sony standalone will play PAL, but only region 0 or 1 discs
    i guess that occasionally they actually make region 0 discs in the PAL format
    my new Sony will only play NTSC discs
    instead of trying to recode/remaster/'repair' your DVD, i guess you could go blow some cash on a new DVD player.....
    from what i have been reading on these forums, trying to convert PAL > NTSC or NTSC > PAL is a total crap-shoot with less than a 50/50 chance of working
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
