Does anyone have an specific preferences for HR-S9911 settings when making a digital copy of an old VHS tape![]()
S-VHS ET : ON - OFF
VIDEO CALIBRATION : ON - OFF
DIGITAL R3 : ON - OFF
VIDEO STABILIZER : ON - OFF
S-VHS MODE : ON - OFF
etc. etc.
The HR-S9911U is the source, ie; my setup is as follows:
HR-S9911U -- TBC-1000 -- DSR-11
Thanks.
ET is for recording SVHS on VHS tape
Only do that if using good tapes (like TDK EHG)
Calibraion ON, controlled by MODE.
I use AUTO most time. SOFT can remove noise
Leave on EDIT to record.
Stabilizer cannot coexist with TBC.
Not often needed, actually.
Off during recording.
S-VHS, again, for S-VHS recording (or ET)
DNR/TNC .. on
Read this:
http://www.digitalfaq.com/dvdguides/capture/playback.htmWant my help? Ask here! (not via PM!)
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
one addt'l comment would be that sometimes I find the stabilizer helps ... maybe not often, but if you feel like it, watch a few mins w/ the tbc/dnr and the same few w/ the stabilizer and see which you like better
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
And sometimes, having both stabilizer/TBC off, and unit in EDIT mode can help too, on really ragged tapes.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
Problems in copying DVDs that were "dubbed" from VHS
By Quonzer in forum Newbie / General discussionsReplies: 10Last Post: 4th Apr 2011, 07:30 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
Copying some home video on VHS to DVD
By syilim in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2008, 22:23 -
dvd recorder/vhs copying question
By nobbydadog in forum DVD & Blu-ray RecordersReplies: 6Last Post: 28th Dec 2007, 07:58
