  1. As it stands now the only means to burn anything on my G5 PC is by opening iDVD. I have another program on it that burns MPEGs into DVDs but you need to save it as an image and burn it as one too. I also have a DVD ripper which I'm assuming requires to be burned under a similar principle in other words it's not just a .mov file I can drag onto iDVD and burn. Is there a way to burn image files or other using iDVD or do I have to get Toast or is there a free download that lets me burn image files etc. Also since I only have iDVD I have no way to burn CDs, but the first need is more pressing. Is Toast my only option? For now forget the fact that it might be my best, I will buy it eventually but is there a free download that'll do some of the basics I need?
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Disk Utility burns DVD images, and is located in your Applications/Utilities folder. Also, to make DVD disk images in the proper format after you rip them to your hard drive, you can use the freeware DVD Imager to make a UDF disk image from a VIDEO_TS folder.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  3. Cool, thanks for the help, I'll check that out.
  4. u,, you have not listed what the name of this 'freeware image tool" is and there is not one listed on the website
  5. you can also use roxio popcorn... burns images, discs and VIDEO_TS folders... half the price of toast.
  6. Master of my domain thoughton's Avatar
    England
    PS Disk Utility can also burn CDs. So can iTunes.
    Tim Houghton
    Website • Photography
