I am in search for a external capture device.
Since I use my laptop and it does have USB, I was thinking of getting a capture device. I am wondering what out there you guys recommend that is not over $80.00 that will capture stuff from my VCR and camcorder 8mm.
I saw this one at compusa. Does anyone know if this will be a good purchase?
http://www.compusa.com/products/product_info.asp?product_code=316015&pfp=SEARCH
or this one from Tigerdirect:
http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=580965&sku=A03-7042
thanks 4 your help all
*New Mac user*, been PC user 4 life
CompUSA also sells the DVD Xpress device. Every now and then they will sell it for $50.00 (after rebate).
I have the DVD Xpress, and it makes excellent captures (imho). Using USB 2.0, you can capture at high bitrates (up to 15mbps, although anything over 9.8mbps is outside of the DVD spec). The nice thing is that it captures both the video and audio and sends them to your computer via one usb connection (i.e. no need to have a separate audio connection to your sound card).George -
Nope no fireport, but I can get a fireport PCMCIA card. What you got in mind??Originally Posted by jdizzy40
VHS capture hardware (again)
By ccooper in forum Capturing and VCRReplies: 37Last Post: 25th Nov 2009, 14:25 -
By Tom` in forum Capturing and VCRReplies: 12Last Post: 16th Jun 2009, 16:42 -
Need Vista64bit capture hardware/software...
By nhgawe in forum Capturing and VCRReplies: 1Last Post: 19th Apr 2009, 17:26 -
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 14:39 -
Are there any external HDs I can capture to?...
By Mark Smith in forum Capturing and VCRReplies: 17Last Post: 6th May 2007, 19:17
