is it ok to set the minimum bitrate to 0 for all sources? will it make the quality not as good?
Generally. if the encoder is a good one, setting it to 0 is fine. If you set a high max, and have a high average, then it gives more room to move when allocating, although there is a risk of it dipping too low. Generally, you should be able to set a minimum of around 2700-3200 for pretty much all sources.
Read my blog here.
It will never be zero anyway. Setting it to 0 just let's the encoder use it's best judgment, which is fine.
In theory, if you set the minimum to 0, your encoder could conceivably attempt to encode frames with a very, very small bitrate. In practice however, many people encode with this setting with no apparent ill-effects, so .....
I always think of the minimum as the lowest bitrate I want the encoder to use, and I always set it higher than 0. Just a preference/habit thing, I guess ....If in doubt, Google it. -
depending oh where your average is, the higher the min, the lower the max. In order for it to be an average, you need to, at the end of the process, have as much data above the average as you do below. If you have an average of 5900, and set your min at 4200, theoretically, to meet you average, the encoder should not use more that around 7600 max. This could hurt you if there is a lot of action. At the same time, your slow scenes may end up being allocated more data than they really need. Most encoders seem to have a certain degree of flexibility, and will move above and below the figures you set in order to achieve the best image for the average bitrate you require.
Read my blog here.
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 09:44 -
Error in Variable bitrate (VBR) audio detected
By Russo in forum AudioReplies: 9Last Post: 12th Feb 2010, 08:01 -
bitrate lower than set when VBR rendering in Vegas 8
By gtmb in forum Video ConversionReplies: 2Last Post: 29th Sep 2008, 07:02 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 09:44
