With every version I've used, when dragging an asset up to the VTS
layout panel I have to drag it twice. The 1st time nothing happens, the
next time it works. Is this just my PC [the only one I have S2d installed
on - XP HOME, SP1] ?![]()
While I'm in here, another "funny" - every time I start up S2D it checks
floppy drive A: Wzzup wit dat ?![]()
Cheera P-PA![]()
I shall look to resolve the first issue.
The second is because the log file includes some system information about your HDD free space. It would seem that the API also checks all disks.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
This happens to me too.
The solution is to click the asset once to highlight it, then click and drag it into the VTS.
It requires 2 clicks, not 2 drags. The first click sets focus I think.
Monster -
m0n5ter: That is correct. BTW it is fixed now in my development build & so will be in the next release.
Layout of mediainfo
By pooksahib in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2012, 10:30 -
Asset Play in SVCD2DVD
By PerryM in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th Aug 2009, 13:47 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 12:28 -
blank asset menu
By anakin1312 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 06:21 -
Remove asset button?
By coldracerx in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Aug 2007, 22:13
