Hi ,
I'm so disappointed : after more than 50h00 of work, I've a crash with DVDLab whatever I do (I've even tried to restart my computer)
When I launch compilation, it crash (15 triess, same crash report)
When I try with few materials (2 sub-menus and 4 slideshows), it works
I've even tried with DVDLabPro (2 different versions). Same crash report :
Exception code: C0000005 ACCESS_VIOLATION
Fault address: 77E578CE 01:000168CE C:\WINDOWS\system32\kernel32.dll
Call stack:
Address Frame
77E578CE 0007F848 InterlockedDecrement (+9)
004637DD 0012F414 0001:000627DD C:\Program Files\DVDlab\DVDlab.exe
0066AC18 0060F4CA 0002:00003C18 C:\Program Files\DVDlab\DVDlab.exe
8B2DEB0C 75FF7FEB 0000:00000000
Results 1 to 14 of 14
I can onlt suggest two things.
1. Download the latest updates for DVD Lab Pro and try again
2. Check out the mediachance forums at http://www.mmbforums.com/phpbb/ and look for your problem or post a question there. The author checks these regularly and it's the best place to go for technical issues with the product.Read my blog here.
Thank you but :
1. I've tried 3 different versions of DVDLab
-last normal release
-DVDLab Pro Beta 2 (1.4)
-usual DVDLabPro
2. I sent to Mediachance the problem -
What are your computer specs? DVD-Lab takes up a lot of resources when it runs
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die." -
Windows XP Pro
1.2 GHz processor and I think 128 or 256 Mo RAM
I read it was created for Windows 98 in the beginning so it should work correctly on my computer, should'nt it? -
Not necessarily. If you're trying to run DVD Lab on only a 1.2 Ghz processor and possibly 128mb of RAM, you're bound to have problems. Like I posted before, DVDLab eats up a LOT of resources when it's running. DVD Lab was created in 2001, so no, it wasn't maybe specifically for Win 98 in the beginning, especially with a 4GB file size limit in Win 98.
In reference your complilation error, do you have any motion menus in your project? If so, remove all of them and recompile, adding each one at a time until you get the crash again. 9 time out of 10, there's something wrong with the video or audio in the motion menu."Hello. My name is Inigo Montoya. You killed my father. Prepare to die." -
Especially if you used DVDLab's internal mpeg creator. Better to use it's avi creator, then encode separately.
Cheers, Jim
My DVDLab Guides -
I don't know how it does with Slideshows (as it appears you are doing slide shows).Originally Posted by thxoptimizer
What are the picture resolutions you are using?George -
I have used DVD Lab Pro to create slide shows without any problems, however I prep the slides to the correct size first in photoshop. Generally though, I create slide shows elsewhere and bring them in as video assets.
Read my blog here.
Yeah...but if I must take each slide and resize it with Photoshop, it will take a lot of time.Originally Posted by guns1inger
My images have many different sizes, but I think it is taken care by DVDLab !
Same thing for the encoding elsewhere and I don't understand very well this :
I added transition between menus but even when I didn't, it crashed anyway.Originally Posted by reboot
For equinox137, I tried yesterday with a most recent computer (bought 2 months ago!) : 1.5 Ghz and 512 Mo RAM so it isn't the problem here. -
I 've just find the problem : I thought DVDLab will associate Sub-menus with titles and slideshows with chapters but it didnt'.
(I found this by deleting 80% of my project : I keep just the root-menu, and sub-menu1-1 and sub-menu 2-2 each one with its 10 slideshows and it worked; so I saw it when I use a DVD-payer)
It seems there is no solution to choose what is a title, and what is a chapter, am I wrong?
We can't do nothing with the green title symbol : it can just be linked with THE root-menu
Is there a solution to tell DVDLab to sort titles and chapters?
Trying to fix my GoPro's crash footage, please help!
By Charlesbusa in forum Newbie / General discussionsReplies: 35Last Post: 18th Oct 2011, 19:24 -
Avidemux Crash Problem
By rock99 in forum SubtitleReplies: 7Last Post: 5th Feb 2010, 08:09 -
The best joke I ever made that no one understood
By Nitemare in forum Off topicReplies: 32Last Post: 7th May 2008, 14:40 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 01:38 -
Problem ripping CRASH
By vice86 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2007, 10:27
