I have a problem and after googling for a couple of hours with no luck I will try here. I have found similar problems, but no solutions that work for me. You guys are always helpful.
Neither Internet Explorer or Firefox will let me access any of the SprintPCS web pages past the welcome page. (Actually, occasionally I can get one link to work, but not often. IE has done this to me for a while, so last night I downloaded Firefox to see if that would help. It doesn't. This is the only web site I have trouble with! IE gives me the standard "page not found" page, while Firefox says "no data on this page."
I use Norton Internet Security and Antivirus, and Ad-Aware for Spyware detection. Also using Windows XP SP2.
Any ideas?
Results 1 to 9 of 9
turn off firewall and see if it works
did you try turning off your router firewall?
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
No, but my husband's laptop goes through the same router, and I don't have the problem on his machine. So I don't think that is it.
in IE , go to the options and TEMP turn security to low -- and see if it works ..
that way you can at least narrow the problem down .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Tried that, already, as well. I have also cleared my cookies and my cache. Nothing seems to help. It is a frustrating mystery! Occasionally I will be able to get through a link or two, but then it stops. I think something in the security settings somewhere makes it time out. But it only happens on this one web site.
if the site uses java - it also may be a messed up java install .. you might want to install the latest version directly fom SUN
What browser are you using these days?
By johns0 in forum PollsReplies: 60Last Post: 28th Aug 2012, 20:30 -
cheapest way to get a browser on a TV??
By sludgepickle in forum Video Streaming DownloadingReplies: 4Last Post: 18th Mar 2012, 10:45 -
video browser
By butterflies in forum Software PlayingReplies: 8Last Post: 29th Jan 2010, 04:13 -
Best Web Browser for OS 9.1
By blinky88 in forum MacReplies: 1Last Post: 26th May 2008, 16:11 -
How YOU get a Ghost In Your Browser
By ahhaa in forum ComputerReplies: 3Last Post: 3rd Jul 2007, 16:20
