I have a DVD which appeared to have one movie only, but when I look at the directories using my PC, it has two VTS folders...VTS1/VTS2
The VTS2 contains a whole extra movie.
Is there a known way to get at the second movie using my standard DVD player if the second movie does not appear through a menu?
Alternatively can I delete the VTS1 from the image on my HD, rename VTS2 and burn it to play the second movie on a new disc.
Any thoughts?
Thx in advance
Can you post the exact content of the DVD, starting at the root? Do you have a VIDEO_TS folder and an AUDIO_TS folder?
jeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
What program do you use for accessing newsgroups?
By johns0 in forum PollsReplies: 15Last Post: 24th Jul 2010, 12:06 -
Accessing an 8 Year Old CD-R
By Soopafresh in forum MediaReplies: 1Last Post: 10th Feb 2010, 08:13 -
Problems accessing certain websites
By wan2no in forum ComputerReplies: 7Last Post: 1st Jun 2008, 10:41 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 11:28 -
Difficulty Accessing Video Help
By usually_quiet in forum FeedbackReplies: 7Last Post: 14th Apr 2008, 17:11
