I have 2 bin and cue files for a 2 x 700Mb SVCD movie. Can I burn them together on 1 DVD media in Toast Titanium 6.0.9?
Or should I convert and join them first in i.e ffmpeg?
Results 1 to 16 of 16
Yes I know that, but HOW will I burn it in Toast? Put folders CD1 & CD2 in ISO 9660 burning, or just the bin files or how?
Place both .bin files in a folder making sure they are named sequentially. (avseq1.bin, avseq2.bin etc.) In the registered version of ffmpegx go to the tools section. click one of the browse buttons then select the folder containing the bins. Hit the "s/vcd>dvd" button, this will produce a folder called DVD which you can drag onto the Toast Data UDF tab. Burn.
And you made us explain the whole thing? Use Galactica's Tutorial The audio conversion should be available in the free version of ffmpegx.
Have you tried adding the bin files to Toast Video format? Sometimes it will take things you don't expect.
The easiest thing to do is:
-Launch Toast and from the Utilities menu select "Mount Disc Image"
-Select the .bin file and click OK. It should mount on the desktop.
-Repeat for the second .bin file
-Select Video format and drop in the two mounted SVCD. The MPG files should be added.
-Set Toast to DVD and burn. -
a very fast solution is to get vcdgear it is free takes about 2 min for each bin file then burn mpg files however you like
I use record now works awesome give it a try
http://www.vcdgear.com/ -
did you try my tutorials suggestion?
its really quite easy. Man i need to update my pages!!!!!! -
Yes I tried some things, First converting to AVI format (was XviD) and also made a test to check the VIDEO_TS button, hopinh to get a VIDEO_TS ready to burn. But no.
When encoding XviD to DivX the ffmpeg could stop at 108%??? and I could not open the movie in QT where I normally can open DivX?
I will now try to convert from DivX to DVD format (with VIDEO_TS and VOB) that always works,
If I can get the converion to work
it does seem that sizzles site is down. I wrote that tutorial before 0.5b came out so i was using the version previous to that. Lots of people tell me that 0.5b wont accept mp2 so im assuming you just convert it tover to ac3 using ffmpegx.
Another thing you could do is rip out the mpeg's and use toast to compile them a dvd under the video tab, but if you really want to use sizzle try changing the audio to ac3 instead of mp2
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 09:25 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11
