The ISO when burned to DVD cannot be detected "UNKNOWN FORMAT".
My computer detect it as a CD not a DVD. Why?
Results 1 to 11 of 11
burned with?
dvd-r?dvd+r media?
tried a different dvd-rom or dvd writer ?
Maybe just a bad burn or crappy media. -
when you explore the dvd disc, you should have the VIDEO_TS and AUDIO_TS folders in the root directory -- is that what you see?
George -
I can't see anything. My dvd drive detect it as a CD. ISObuster can detect the content though.
I use ulead movie factory to create the ISO. I can play the ISO using Media player classic, but when converted to DVD using (dvd decrypter, ulead movie factory) thats the problem comes out. PowerDVD error - unknown format -.
I lost two DVD media.
did you just burn the dvd.iso image to dvd? or did you use Ulead DMF to burn from the dvd.iso image? What was used to do the burn?
George -
Just normal burn.
I used both dvd decrypter and ulead DMF.
I found forum discussing about error when ISO got ULEADDMF folder.
My ISO got this ULEADDMF folder. -
Originally Posted by vocalmindGeorge
is the disc still "open"? what software did you use to burn the image? and was it burned as a DVD, or a data disc?
George -
Burn as DVD. I think I got it now.
Ill settle that DVD decrypter cannot burn (properly) ISO with ULEADDMF folder.
By the way. Is this DROP FRAME during DV transfer (firewire)? ( pardon me, I know its off topic )
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 08:48 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 03:48 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 13:12 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 07:14
