Hi Chrissy
A couple of points noticed this morning.
Trying a compliation with six movies.
On the left under "Windows" with the 6 reel icons displayed the text for icons 4 and 5 is the same. The displayed text changing depending on which one of the two you last clicked. Correct details are shown in the main move details panel.
On the menu the presence of an "&" sign in the button text causes the text after the "&" sign to be displayed as ??shade?? rather than in the font colour.
Malcolm
The & thing i will look into.
Can you replicate the first issue again? If so can you outline the steps i would need to replicate this also?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I will look at it this afternoon/tomorrow morning and try to work out exactly what I did.
Malcolm -
I cannot now replicate the first issue despite trying about 12 times.
At the time I did replicate it twice but did not note exactly what I did.
In the session where it occured the only other thing I had done was to install a Java runtime update after deleting the previous version in an earlier session. I had not rebooted the computer before opening SVCD2DVD. It maybe that something left active from the Java installation affected the running of SVCD2DVD.
Unless others have had the same problem I would suggest the issue be closed. I will contact you again if it recurs.
Thank you for your assiatance, and my sincere apologies for the time you wasted in looking at this.
Malcolm -
No problem. Keep me posted.
ThanksSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Subtitle Glitch
By KingMisfit in forum Video ConversionReplies: 2Last Post: 8th Jan 2012, 13:46 -
Is this a VH glitch of some kind ?
By Seeker47 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2009, 14:09 -
imgburn 2.4.4 glitch
By johns0 in forum ComputerReplies: 23Last Post: 15th Jun 2009, 02:25 -
ZUNE 30 Software Glitch
By Number Six in forum Portable VideoReplies: 6Last Post: 1st Jan 2009, 15:40 -
MKV2TS glitch...PLEAs HELP!!!
By carlitos287 in forum ProgrammingReplies: 0Last Post: 12th Aug 2007, 00:22
