My problem is when i convert an avi with tmpgenc i lose the sound. i know this question has been asked many times and i have been reading the various guides and replies but none of them seem to help me. but if i missed a guide or something could someone direct me to it?
i even reinstalled tmpgenc but there's been no change. I've tried doing what it says in the avi to wav guide by converting the sound to wav with virtualdub and then encoding with tmpgenc but, i still get no sound after it's been encoded.
i tried just playing the wav file in my audio player (quintessential) and windows media player and the wav file worked fine. When i play the original movie file in my media player it works perfectly.
everything was fine until a week ago. i was even able to convert the same file i'm trying to now successfully. but i deleted it.
i deleted all my video and sound codecs and reinstalled them again but i still can't get sound when i convert with tmpgenc. so i figure my problem is most likely a codec problem but i have no idea what codec i am missing. the codecs i have installed are:
ffdshow mpeg-44 video decoder
divx 5.2.1
Indeo
AC3-ACM
Core Vorbis
3ivx codec 4.0.4
XVID (Koepi)
Ogg-acm
Divx 3.11 alpha
Ac3 Filter
Oggdso995
fraunhofer Mpeg layer-3 Audio Decompressor
Lame 3.95
Wm9 Codecs
So would some be able to help me out with my problem please. any help will be greatly appreciated. thanks.
Results 1 to 14 of 14
i've always had the dshow plugin set at the top of list but i still get no sound.
Extract the wav in virtualdub in full processing mode and then use that wav to encode with.
Well the thing is last week i was able to successfully convert the same avi file to a vcd but i deleted it. I've been converting the same sort of files for a year and all of them were successful.
I've increased the dshow plugin till 4 while the others are at 0 or lower. i've tried extracting the audio and converting it into wav, then inserting it into tmpgenc but i still get no sound.
A few days ago i deleted all my audio and video codecs and reinstalled them. But now i'm not getting audion when i convert with tmpgenc, so that's why i think i'm missing a codec but i just don't know which one. -
I had same problem after installing new FFDSHOW.Tried everything and decided there must be a conflict with the audio somewhere.I see you have lame mp3 and ac3 as I did .What I did was uninstall FFDSHOW and when I reinstalled I unchecked mp3 under audio codecs as I was installing again.It gives you optons to use for video and audio.I dont have any more problems and its working great with new FFDSHOW build.
You can go into the audio config and enable/disable anything you want. No need to re-install.
How do you enable/disable?I open up audio config and see mp3 diabled in codecs but cant find where to enable? Audio settings just have default.Is it somewhere in there?
Disabled = disabled.
libmad = enabled, using libmad for decoding.
mp3lib = enabled, using mp3lib for decoding.
Not that hard really. Anything that is not set to disabled is enabled. -
I know what it all means but you still have not answered my question.If for example I have mp3 enabled what would I have to do to disable it or vice cersa?Is it in the codecs window or the audio ?Give me a step by step of what to do once I open the FFDSHOW configuration.ThankYou
Missing Codec?
By jimbb in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2011, 14:54 -
Codec missing virtualdub
By tkitez in forum Video ConversionReplies: 25Last Post: 12th Jan 2011, 20:42 -
Missing a codec?
By jnojr in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2008, 17:24 -
Codec missing
By breeze9 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2008, 21:08 -
Missing Codec
By arileysr2 in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 13:13
