In Event Viewer, I noticed the following message appearing almost once a day for the past 3 days:
The driver has detected that device \Device\Harddisk2\DR2 has predicted that it will fail. Immediately back up your data and replace your hard disk drive. A failure may be imminent.
Data:
0000: 0e 00 03 00 01 00 5e 00 ......^.
0008: 00 00 00 00 34 00 04 80 ....4..
0010: 02 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 11 2d 00 ......-.
0020: 00 00 00 00 00 00 00 00 ........
0028: 00 00 00 ...
The problem is, DR2 is not a meaningful designation for a drive. I have 8 HDs on my system. Obviously drive letters don't mean a thing because I changed drive D: to O: yesterday and Event log still shows DR2 as imminent for failure.
The disk arrangement in my system is as follows:
Primary Motherboard IDE controller:
1 HD as master in first channel (C: - OS)
1 HD as master in secondary channel
SATA controller on southbridge chipset
2 HD attached
GigaRAID IDE controller
2 HD in primary channel
2 HD in secondary channel
And I am running WinXP-SP2. Anybody has experience as to what this "Harddisk2\DR2" means? I looked the whole thing up in Microsoft's knowledgebase and support sites and the only relevant hit was the following:
http://support.microsoft.com/default.aspx?scid=kb;en-us;830051
which relates to Event 51 and Windows 2000 SP4. Event 51 (although close), has to do with cache not supported by a drive. And I am not getting tons of them. Only one per day.
Thanks in advance to anyone who can help.
The more I learn, the more I come to realize how little it is I know.
I don't want to give you any wrong information on determing your drive #, so I won't
However, if you have S.M.A.R.T atributes turned on in bios, you might be able to determine the bad drive using an small app called DTEMP
http://private.peterlink.ru/tochinov/
Just unzip and run it. It will load into your system tray. Right click on it to see the SMART attribute info. -
Thanks a lot for the link. DTemp verified my suspicion that the offending drive was one of the brand new SATA drives. Thankfully it also displayed the serial number of the drive (and thankfully Western Digital records serial numbers to their drives) so I am able to easily identify it.
Again this proves the theory that a HD will fail either within the first month or after a long time.The more I learn, the more I come to realize how little it is I know. -
I Absolutely agree with that. It will either die immediately, or after 5 years.
Philips DVDR 7260H Hard Disc Crash
By ikcdab in forum DVD & Blu-ray RecordersReplies: 3Last Post: 27th Apr 2010, 22:58 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 13:48 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38 -
Panasonic E80 hard drive crash
By csanders1962 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th May 2007, 17:57
