Thank you for any help or suggestions you can give!
I am trying to convert a Div-X file to VCD/MPEG-1. I am using:
- Windows XP
- TMPGEnc 2.01
- Roxio Easy CD Creator 5 Platinum (VCD Creator) with XP patches
I can successfully convert the DivX to an MPEG-1 that is VCD-compatible. When I open the mpg up with the Roxio program, it is willing to create a VCD with the file. Unfortunately the file size is too big for a single disc so I have to split it.
Now I CAN split the file using TMPGEnc, but when I try to burn a VCD using the Roxio program, it tells me this:
"The file 'whatever.mpg' will not work in a VCD player. To make this file video CD compliant, you will need to use an MPEG encoder that supports Video CD encoding." \
It then says that the System Clock Reference (I have no idea what that is) is "Not acceptable" and says that it is 1058. There are exclamation points next to Video Pack Size (2048), Audio Pack + Padding (2048), and Last Pack Size (2052). The exclamation point apparently means "probably OK".
Please help! This is so frustrating. If this cannot be fixed but you can suggest a better freeware splitting program, I would love to hear it. I tried to split the DivX file with Virtual Dub but when I go to save anything in Virtual Dub, a warning window says "The video mode must be set to Full Processing Mode for video compression to work". But I *DO* have it set to Full Processing Mode, and it still doesn't compress.
This is my first effort and I am extremely frustrated at this point! I appreciate any help.
Kind regards
Mark
<font size=-1>[ This Message was edited by: HongKongFooey on 2001-12-08 19:44:54 ]</font>
<font size=-1>[ This Message was edited by: HongKongFooey on 2001-12-08 19:45:30 ]</font>
when you split the mpg in tmpge make sure you change
the mpeg-1 system{auotmatic to
mpeg-1 video cd and it should fix your problem. -
Staind, thanks much for your help! That was indeed the problem. However, when I try to play the VCD, I don't get any sort of playback. I have a Toshiba SD-1300 which has been verified by other board members to successfully playback CDRs. When I pop in the VCD, the machine says "PLAY" but I get a blank/black screen.
Any ideas?
thanks. I am posting this to the playback board as well.
Regards
Mark
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18 -
TMPGEnc - bad frame problem
By psyklax in forum Video ConversionReplies: 5Last Post: 30th Jun 2007, 22:44 -
Trutech 1620 clock
By jaybird206 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jun 2007, 14:20
