  1. I have a vcd burned to disc, but i want to edit it, but i need it to be in a avi or mpeg format, is this possible?
  2. Member MpegEncoder's Avatar
    The VCD has an mpeg file on it. Use VCDGear to extract it.
  3. The cd has 5 files on it
    CDI
    ext
    mpegav
    segment
    vcd.
    I dont see any bin/cue files in there, do you know which XXX-->mpeg i need to do?
  4. Originally Posted by lakercl9
    CDI
    ext
    mpegav
    segment
    vcd.
    There's a file named AVESEQ.DAT in the mpegav folder. VCDGear should be able to create a MPEG-1 (since it's a VCD disc) for you.
