Results 1 to 11 of 11
  1. Banned
    Dec 2004
    SE4
    Hi watching a movie on a kazaa lite codec based computer i get lines thry the vobs from a dvd its wierd..ive only noticed this on the vobs of movies playing this in VLC (the media player that doesnt require codecs) and BSplayer (the player that does require codecs) and i sitll get the same picture, on movements the picture is all liney..this cant be a codec issue, can it?? cosi played it on vlc..
    what the hell is going on here guys!?!?!!?!??!?
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    There is no such things as a kazaa litee codec. Use gspot to find out what the real codec is. Its also possible your file is damamged beccause kazaa is bad about that.
  3. Originally Posted by jason69uk
    eh ? are you watching a dvd or have you ripped the vobs to your HD ?
    I'm assuming by kazaa lite codec you mean the kazaa lite codec pack ?
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  4. Banned
    Dec 2004
    SE4
    sorry im talking shit again..
    K-lite Codec pack i meant.
    sorry
  5. Banned
    Dec 2004
    SE4
    well........
  6. Originally Posted by jason69uk
    well........
    I still have no idea as to the extact nature of your problem.
  7. Banned
    Dec 2004
    SE4
    Sorry yeah, yeah i ripped the vobs to the hard drive..
    Have a DVD? Use a DVD player.
    Installed a codec pack? You probably hosed your system. Use DXMAN and take off unneeded codecs.
    Dec 2004
    Australia
    Sounds simply like an interlaced source.
  10. Banned
    Dec 2004
    SE4
    Hi, this often happens wioth divx but very rarely, only with vobs but only time it does it with vobs is when ive copied them with dvd decrypter..
    Also does using dvd decrypter damage the writer or the dvds??
  11. Member otpw1's Avatar
    Jan 2005
    midwest USA
    No! If it did there wouldn't be a happy camper on this forum!
    A good divorce beats a bad marriage.
    Now I have two anniversaries I celebrate!
