My agency has charged me with the task of recording four different simultaneous cable broadcasts every day. They are currently using four VCR's, but are unhappy with the results. Short of buying four DVD recorders, which I may do, does anyone have any ideas?
I wouldn't think you could capture more than one show to a computer at a time. Is there some commercial grade device with multiple tuners capable of recording more than one channel or input at a time? Pretend that money is no object. I am open to any and all suggestions.
To me, four DVD recorders appears to be the way to go for simplicity's sake, if nothing else. If you agree, can you recommend a good stout recorder capable of recording every day on RW's?
Thanks for all of your help.
Kyle
See here, your job is done.
http://www.byopvr.com/displayarticle168.html
Depends if you want material on DVD or on HDD. -
If you're just going to put the video onto DVD without editing it, DVD recorders are the way to go. It will be SO much more simple.
If you have the need to trim / edit the video then look into a PC.
That's my opinion anyway.
DVD recorder digital tuners
By joecass in forum Newbie / General discussionsReplies: 80Last Post: 19th Apr 2011, 12:51 -
where do I purchase tv tuners that are cablecard ready?
By craig198 in forum Media Center PC / MediaCentersReplies: 13Last Post: 29th Jan 2011, 19:19 -
TV Tuners in Windows 7 x86
By jznomoney in forum Capturing and VCRReplies: 0Last Post: 10th Aug 2009, 17:44 -
QAM Tuners
By hd999 in forum DVB / IPTVReplies: 3Last Post: 23rd Dec 2007, 20:29 -
HD Tuners
By sponge in forum Newbie / General discussionsReplies: 7Last Post: 22nd Dec 2007, 05:21
