I am using Shrink 3.2 and when I shrink my movies, I get a back-up that plays the DTS movie track, BUT the DTS intro (piano scene, etc) does not play any audio.
What gives?
How can I keep that track of the DVD?
I notice after the initial analysis done by shrink, it will uncheck the DTS box. I will physically put a check mark in the DTS box and thats it.
Any help is appreciated.
Thanks.
If you aren't keeping the menus, then the script (links to all the intros like the Studio banner, DTS, DOLBY, THX, FBI warnings) is gone.
Google is your Friend -
He obviously IS keeping the material he wants because he said he see's it but does not hear it
Even though you recheck the DTS option for the main move, any other DTS audio is still removed. you have to look through the other folders and also check the other DTS audio.
And if you use reauthor you can keep anything you want with the movie you just won't have the menu's. -
Thanks guys.
I havent had time to follow up. But when I wrote the original post, I was backing up a movie.
When I got back to it, the DTS was fine....this time, so I dont know what I did different but the sound is there on this last movie I did.
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
