  1. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    2.0 RC 5 - Released 23 Feb 2005
    - Fixed: AVI’s with NTSC (Film) framerate produce larger than expected DVDs
    - Video Elementary stream mpegs are now able to update the DVD capacity indicator.
    - Auto Layout for Assets is improved with smarter logic.
    - Menu looping is back – I broke it back in RC1
  2. I'm trying it now... looks sweet so far
  3. Ok, it still crashes when i try the menu preview
    edit 24.14:
    w00t i just burned a dual layer DVD with a music menu. It works like a charm!
    Kickass software man!
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    edit 24.14:
    So does it crash? If so what error messages are you getting?
  5. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I was trying it, as far as it made it it looked good but i keep getting this.
    I'm betting it's just me
    Usually never mess with (s)vcd stuff but i saw the option for pal to ntsc so i thought i would mess with it....
    Does about 2 minutes out of a 21 minute file.
    Mar 2002
    I used AVI assetts for the 1st time i used 5 assetts which were well over the 4.5 gb allowed so used auto fit and it put it to exactly 4.5 created the dvd fine but whenn it was complete it was only 3.11 gb so i lost 1 gb somewhere?, also one of the Avis on the finished dvd was quite a bit out of sync but the orig wasnt?
