    Apr 2003
    hi there,
    i have a weird problem.
    i recently purchased a Satellite receiver (Manhattan PLAZA ST300) - i have used its S-Video out option directly into my DVD recorder.
    when i watch it, i can see faint verticle lines all the way across the screen, its very noticeable if the screen brightness on the TV is up.
    i havent tried an RGB out direct to TV yet as i dont have enough scart ins, on my DVD recorder (panasonic e50) so i thought my best bet would be S-Video out.
    could it be a cheap cable getting interference?
    any advice would be great.
    many thanks!!!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I've seen this before, and it seems to be caused by the S-Video output or cable (I didn't trouble shoot - just changed from S-Video to RGB).
    A better cable may be the fix.
    Google is your Friend
