I am capturing DV home movies from a DV camcorder and want to burn DVDs with simple one layer menu pointing to each clip.
I am starting to try the different TmpgEnc versions with alot of help from the forums here and actually having SUCCESS after 2 years of on & off trying & getting frustrated with all different ways of doing this.
My question is which TMPGenc(s) to buy/use.
There is Plus 2.5, Xpress 3.0, or DVD Source Creator 2.0 to do the encoding. Does it matter which?
It seems that Plus is a litttle older and can't use the AC3 plugin. But if I author in TmpgEnc Author, can I use the AC3 plugin there to make my audio AC3?
DVD Source seems to be XPress, but without as much flexibility. Do I need the flexibility of XPress if I am just doing DV to DVDs?
And I can't use the free Tmpgenc since it is just Mpeg-1 right?
Thanks for all the help
True about the free version. I have used them all at one time or another, and prefer tmpgenc plus 2.5x because it's got more stuff I can fiddle with
They're all slow compared to most other encoders, so before you buy, I would suggest you download and try as many others as you can.
Mainconcept mpeg encoder, CCE and Canopus Procoder are all much faster (in most cases).Cheers, Jim
My DVDLab Guides -
I use Mainconcept Encoder. It is faster than TMPGEnc and I could not detect much difference in quality between TMPGEnc Plus and mainconcept - at least not to my (average) eye for home movies.
*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
Use the latest TMPGenc plus.
I don't like xpress (and the final picture quality IMO is the same with TMPGenc plus)La Linea by Osvaldo Cavandoli
I agree. I tried the trial version of express and was not impressed. I'd go with TMPGenc plus (it's the version I own).Originally Posted by SatStorm
Later!
RogThere are many ways to measure success. You just have to find your own yardstick.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
