Hi everyone, this is my first post.
I have a problem capturing video with Vegas 5. I have my VCR connected to my camcorder Sony camcorder (Digital 8 ) via firewire. Windows does recognize my camcorder. As I am trying to capture video, there is audio but no video in the preview window nor does it allow me to press the "record" button. In fact, the video plays for 2 seconds and it stops while you can here the audio. Instead the preview window says "Please insert tape" with "need help? click here". I try to reconnect to the device and still the same thing. Do i need a plug-in or what?
Specs:
P4 3.0 ghz HT w/ 800 fsb
WIN XP PROF ED... sp 2
A-OPEN AX4C MAX II
2x 512mb (1 gb) (3200 DDR)
256 mb NVIDA GForce FX 5600 XT w/tv out
WD 120 gb
WD 160 gb (for video)
Audigy 2 zs Platinum
Results 1 to 16 of 16
Is the quality better using this program versus windows movie maker? And should i use type 1 or type 2 avi. I want to burn a 2.5 hr video onto a dual layer dvd.
quality is the same - the compression is done in the camera ...
what would you guys recommend...avi type 1 or type 2? I have been using windows movie maker for a while, what did that use (avi type)?
I want to make 1 big 2.5 hr avi and it made two seperate tracks in the first 20 minutes..how can i stop it from doing that?
Take alook here , has many answers to questions you may have about the App.
http://www.dvd-guides.com/content/view/33/59/ -
If using WINDV make sure to check your audio sync near the end of your long captures >45minutes.
Sony Camcorders(including mine) have been known to have issues with these programs when using passthrough mode due to lack of an audio lock feature.(there are some good threads explaining this.)
I have heard if you capture type 1 that it sometimes fixes the problem.
But if you don't have the issue then don't worry. -
I just checked the file and it is a bit off. Is there a way in correcting this problem with sound or do I have to re-record?
ok.....i see that I have to use virtual dub to correct it. Does Virtual dub do the same thing (audio sync problems) when capturing video or will it be fine? Does virtual dub also give me an option to record on type 2 avi?
I think this may be the issue:Originally Posted by pontios
First make sure the camcorder itself is recognized by playing a short tape segment. If you see no video then you need to reinitalize the IEEE-1394 link and choose th right IEEE-1394 source.
Your Vegas 5 capture probably has DV device control set to on. When captureing in pass-thru mode, you want the camcorder to remain inert. You will be manually controling the VCR and "Capture Video" buttons.
Under Capture window, Options, General, the first line "Enable DV device control" should be unchecked for pass through. This also applies when transcoders (e.g. Canopus ADVC) are used. -
From my understanding Virtualdub cannot capture from firewire, at least it didn't when I tested it a while back, maybe things have changed, maybe not.Originally Posted by pontios
Try what edDV tells you and let us know.
There are ways to fix the audio issue in Audacity and Goldwave(both free) but I try to avoid this issue all together and don't capture to WINDV, DVIO, or DVAPP.
What I have tested that worked is Ulead VideoStudio, Premiere, Vegas, and Scenalyzerlive, choose your poison. Havn't tested windows built in Movie Maker so don't know on that one, didn't have winXP back then.
Good luck. -
wooohooo!!! DONE! I unchecked the "enable device control" and it works awesome! Ill be using Vegas now on for capture! I just have a follow up question ...does vegas capture in type 2 avi or will i have to convert it into type 2 avi? I have "dv converter" to do my conversions and will I lose video/audio qualtiy when converting?
Vegas captures type 2.
And no you don't lose quality using dv converter.
Imagine me, another problem w/ Vegas! Capture vid & render, no mp4 save?
By damonj_3 in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2011, 13:01 -
DV capture in Vegas not working
By Knightmessenger in forum Capturing and VCRReplies: 22Last Post: 29th May 2009, 09:31 -
Vegas Studio will not capture audio
By mpjbrennan in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2009, 10:24 -
Unable to capture hdv with Vegas 8 Platinum
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 22nd May 2008, 06:10 -
Sony Vegas Pro 8 Capture in 16.9
By Ben17 in forum Capturing and VCRReplies: 18Last Post: 25th Apr 2008, 02:30
