    Dec 2004
    1. Encoded a 25 min. interlaced (VOB) movie 4-5x (using TGMPEnc Plus 2.5, DVD2AVI) at various cbr (2000, 8000) and file size is very high (1.5 GB@8000 kbps). Quality of both is poor on PC (motion blur/combing effect: I read that PC can create the motion blur from interlaced movie) but 8000 kbps file plays fine on DVD. How can I get this file size down and keep good DVD quality? i.e. I've seen high quality movies of this type at 300-400 MB.
    2. What is the best file type to encode to for a standalone DVD player? I've read stuff about mpeg, DivX and Xvid but I don't know which is preferrable. And what DivX/Xvid encoders are out there (think I saw Nandub?)?
    3. I don't know what a header is.
    4. What situation would you use multi-pass encoder and are there any guides for it around here? The way I understand it is the first pass creates a file which is then used for the second pass?
    I have been editing files 12 hrs/day for the last 10 days and I've downloaded at least two dozen different softwares (rippers, encoders, decrypters, etc.) and I haven't even started climbing the bell curve. Thanks much.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    1) If your target format is DVD, why do you want to reencode the VOB at all?
    2) Video m2v (mpeg2) Audio AC3 or MP2 or LPCM - that's what Video DVDs are made of. Some DVD players also manage to play back AVI/DivX/XviD. For AVI/DivX/XviD encoders, see tools, left, and read guides on ??? to DivX/XviD
    3) Put simply, Info at the start (head) of a file, describing the contents of the same, such as bit rate, frame rate, frame size & cetera
    4) When I'm short on media space, and want highest quality possible for the given size. And don't mind waiting 2-n times as long for the finished product.
    /Mats
    Dec 2004
    I want to reencode it to get the file size down so I can share it.
    Anywhere I can go to understand how multipass works?
