Anyone know how to automatically record a complete program on sky digital (without sky+) with a timer?
If I use the auto view function it quite often chops off the beginning of the program or pastes the blue title bar across the bottom. I can't seem to find any manual timer screen...
My HD recorder does not have sat control.
The other option would possibly be an IR remote that had a timer in and you could program it to switch both units on, change the channel & start recording etc - but I can't seem to find such a beast!
MP.
Get Sky+, you won't regret it!Originally Posted by muckypup
But even with Sky+, the recordings only start and stop according to the same EPG info as available on the normal Sky boxes. The advantage though is you can set the device to 'pad' the recording by several minutes (user configurable) at each end to try and avoid problems with EPG and programme times not matching.
Sorry I can't help any further.There are 10 kinds of people in this world. Those that understand binary... -
I'd love sky+ but I have just spent 300 quid on a HD/DVD recorder and I don't think the missus would be best pleased if I bought sky+ as well...
I did consider sky+ but as it's difficult to get the recordings off (I like to archive my programs I wish to keep in DivX format) I opted for a HD recorder instead. If sky dropped the 10 per month extra charge I might consider it!
The pioneer 420 has very good editing facility - I can record, remove adverts & trim to the correct size with frame accuracy and copy to a RW and then encode to DivX on the PC.. If I'm keen I could have the program encoding with half an hour 8)
MP
recording SKY+HD
By snadge in forum DVB / IPTVReplies: 0Last Post: 26th Feb 2009, 12:15 -
Recording from Tata Sky
By planetx in forum Capturing and VCRReplies: 1Last Post: 7th Nov 2008, 21:07 -
What tool is consider more accurate, Mplayer or MediaInfo?
By Maikeru-sama in forum Video ConversionReplies: 3Last Post: 4th Jul 2008, 19:56 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 18:02 -
Sky+ recording to dvd help!
By dollydoodledumplin in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 00:25
