HI
I have my VTS in Hebrew language. I like to translate it to English.
Instead of completely re-author it I thought about extracting the relevant video clip, edit it, encode it and bring it back to the VOB structure.
How can I do it? What tools I should use?
S
VTS in Hebrew? You mean you have a DVD with Hebrew subs, and want them in English?
AFAIK, you cant add/replace a subtitle stream without reauthoring, no.
/Mats -
no i meant the menu that appear when you insert the DVD disk to the player.
Chances are you would have to create a whole new menu, as the text is probably embedded in the background as well as being in the subpictures.
You could try the 30 day demo of DVD Lab Pro. It will allow you to import a VTS from elsewhere and work with it. Tmpgenc DVD Author can also attach to external VTS'sRead my blog here.
Burning VTS
By oldshep in forum DVD RippingReplies: 1Last Post: 8th Mar 2012, 16:13 -
Multiple episodes in one vts
By c9806961 in forum DVD RippingReplies: 12Last Post: 15th Aug 2009, 02:35 -
VTS files
By robertmuller in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th May 2009, 20:54 -
vts to avi
By kiwiflyboy in forum Newbie / General discussionsReplies: 3Last Post: 23rd Sep 2008, 22:40 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 11:28
