hi all.
I have burnt several discs with "mpeg's" on them to join at a later date.
I tried to drag & drop them on to desktop but keep "getting cyclic redundancy check" is the an alternative way of ripping them onto my HDD as in DVD dcpyter?? Rem, these are plain old mpeg's.
??Would "SmartRipper" work?
Pipe
CRC errors usually mean a file on the disk is corrupted. May be that the media you used to store them on is either poor quality or dirty/scratched. You could try setting the Ignore Errors flag in DVDDecrypter and see if that works.
dvd decrpter does not accept mpeg.
discs are ok as I can watch them on dvd player & puter. All I need to do is get them on to my hdd to join.
pipe -
Just because you can watch them does not mean they are fine. When playing on your PC or DVD player, small errors can be ignored and you porobably wouldn't notice the errors on the screen. When copying to your HD, these errors cannot be ignored as the 'puter is trying to make a bit exact copy of the data file.Originally Posted by pipe
Try cleaning the disks gently with soap and water or use a commercial disk cleaning repair product like Skip Doctor.There are 10 kinds of people in this world. Those that understand binary...
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Ripping Music Videos From WTV - DVR-MS - MPEG?
By skywalka in forum EditingReplies: 5Last Post: 12th Jan 2011, 03:13 -
If i ripping a DVD Movie to H264/MPEG-4.
By skorpinok in forum DVD RippingReplies: 4Last Post: 24th Aug 2010, 12:12 -
Ripping straight to mpeg
By NurEinTier in forum DVD RippingReplies: 7Last Post: 22nd Nov 2009, 10:11 -
ripping a avi/mpeg back onto computer
By pw29010 in forum DVD RippingReplies: 2Last Post: 16th Feb 2009, 17:34
