  1. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    Hey yall, i'm trying to batch convert a large group of jpegs to mpeg stills so i can make a dvd out of them. Is there any software that can do this?
    Rog
    There are many ways to measure success. You just have to find your own yardstick.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    JPGVideo turns a series of JPG images to AVI. Really cool. It's then a trivial task to encode the AVI to mpg.
    (Did a really cool timelapse video from images periodically downloadad from a web camera once...)
    /Mats
  3. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    well unfortunately i want all the stills separate. However, i do think that program could be handy if i WAS making an mpeg from still though so i did download it.
    Rog
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Ah - you want a slide show? Well, ProShow Gold is what I use for this (there are many other slide show creators) - but I don't know of any batch conversion utility, I'm afraid... But since you'll have to author the lot anyway, why not let ProShow take care of the whole process?
    /Mats
    canada
    vcdeasy makes mpg stills from pics in batch mode.
  6. Photo2DVD Studio is also a good tool.
  7. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    yes, but it only makes them 352 x 240 or 480 x 480 not 720 x 480. Unless the pay version does different.
    @ Mats & Sanjk:
    Will look into both of these
    Thanks!!!
    Rog
