  1. Hey i am trying to join two mpeg files with TDA but it sed sumthing like they arent dvd files so can sum1 how i can make then dvd and how i can join the two mpeg to one file...guides? thanx
  2. Use TMPGEnc Plus to convert and join. There are plenty of guides in the left pane:
    Regards,
    *** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
    Mar 2004
    Southern California
    TMPGEnc DVD Author has 2 import options, "add files" and "add dvd video". Use add files button for mpegs and add dvd video only if you have VIDE_TS folder containing vob, ifo, bup (or RTAV with vro). Mpeg files must comform to dvd spec or program will reject them. You will only need to convert if mpegs are not to spec.
