Does PVAStrumento generally take a long time to convert? Like for demuxing a .ts 2 hour movie how long should it take?
From my exeperience, from 10 to 15 minutes, depending on the bitrate of trasmission (and hence the filesize that can vary from 2 Gb to 5 Gb).
Hope it helps
Riccardo -
Thanks for the reply. Are you using the default settings? or do you make changes. My files are taking 2 to 3 hours and i'm not even getting a 1gb file.Originally Posted by Riccardom
I use default settings except for "packet size" set at 2048 (for DVD).
My sources are not .TS but .MPG because I use DvbDream to record from satellite and it generates only mpeg files.
Could it be the difference ?
Verify also the DMA status of you disk because the operation is very "Disk intensive" and not working in the best mode can cause a big delay.
Riccardo -
Yes, I always use DMA. I'll have to try an Mpeg file from my Hauppauge Nexus/RitzDVB capture to see if I get the same thing. The TS file is from my Dreambox. I have other means to make this conversion but I just decided to play with PVS.
There must have been something really wrong with the TS file which is why it was taking long. I tried an mpeg file recorded with RitzDVB and it was fine. It was done in minutes.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
