    Dec 2003
    Davenport,Iowa
    looking for some background motion software to create motion backgrounds. I want to lay stills on them and use them for my photo montages.
  2. After effects is great for this. The price is high, but they have a trial version.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You could try Wax - it's free. Or download some - Sony has some, and Mainconcept release a handfull every month. It's all abstract stuff, but full frame.
    You could also play around with the various effects in your editor (most have something) to create your own.
    Having said that - After effects is exactly the tool for this work if you have the budget and intend to do this commercially.
    Read my blog here.
  4. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    i recommend learning avisynth it's powerful and free but has a learning curve. Zweistein is a pretty free video editor. Movie DV is a mid range $50 ish good video editor.
    Later
    Rog
    There are many ways to measure success. You just have to find your own yardstick.
