Getting subtitles to play on a philips dvp 642 is a real pain in the butt. Infact to do it you either have to burn the files on a pc or vpc using nero or if you want to use a mac, you have to use discribe. I found a set of instructions on the dvp 642 hacks section that tells me how to do it, but I cannot get it to work. eesahmuu writes...there's two ways to burn a working .srt CD on a Mac ..
first -> use Virtual PC and NERO to burn ur .avi + .srt using the
default settings
second -> use Discribe and CD-ROM + ISO Level 1 Settings.
well does anyone have an idea of what this means? I set up discribe, chose data disk, inserted my media file, and burned it using both iso-9660 and iso-9660xa. neither worked. I tried burning the file at work using nero as a safety and that one works fine. I really want to be able to do this at home on my mac. Has anyone done this? Any ideas or tips? I appreciate any help you can give me.
thanks!
Toast
Iso Level 1
Avi + Srt
Burn
Bingo!"Good Luck 007"
In Memory of Desmond Llewelyn -
thanks for the tip, however I just tried it and it was a no go. are you sure this works? any other ideas?
Get MissingMediaBurner and try it that way, as a data image. Other than that im not sure. The way I do it in Toast is the way that works on my phillips.
Q"Good Luck 007"
Thanks for your suggestions, here is how I did it with toast. Selected data, selected ISO 9660, dragged in a folder containing the avi and srt (both with the same name) and hit record. When it came out and I put it in the philips, there was no folder in the menu, only the 2 files and the srt file had a ? icon on it. Is this how you do it? Thanks again for your help
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 13:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 03:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 17:26 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 15:36
