  1. Guys please can anyone suggest a freeware to convert .rm to .wmv or.avi or .mpg
    Not related here. but can u please suggest a freeware.
    Iam having boilsoft rm converter but its not at all good.
    Any help would be appreciated
    thanks
    chinnu
  2. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    i bought boilsoft's rm converter
    biggest rip-off i've ever had.....
    what a waste of my money!
    the program is garbage, no matter how you configure it, your resulting files have very bad progressively out-of-sync audio
    their tech-support is bad too -- i asked them how to fix the problem and their reply was in bad Engrish
    they said something to the effect 'use VirtualDub to fix the audio, that's what it's for'
    bastards...
    TINRA is supposed to be good, but I haven't played with it yet, so i can't say for sure how well it does the job
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  3. thanks i will try TINRA
    bastards...
  4. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    don't forget to get the TINRA GUI!!!!!!
  5. Banned
    May 2003
    Massachusetts
    I can suggest a foolproof method - don't use any software or media that is in any way associated with Real Networks. Real = TEH SUKC.
  6. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    sometimes you have no choice
    episodes of Transformers Headmasters for example....
    the show isn't on TV, so you can't capture it. and the only eps for download anywhere are .rm
    Menasor was doing good HQ .avi's, but only did the first 20 or so eps, and they're all but impossible to find
  7. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Tinra will work fine as long as RealPlayer8 or earlier versions are installed. But, if RealOne or RealPlayer10 is installed, it makes Tinra inert and non-functional.
    This isn't freeware ... but EOvideo will convert .rm files to AVI/MPG files.
    Dec 2004
    Australia
    mencoder can read rm files and output avi and mpg.
