ok...i'm reposting cuz last one didn't get must attention.....
i ripped Bridget Jones's Diary using both smartripper and dvddecryptor and both had the same results....
i'm trying to add subtitles to the movie and came up with an error..i talked to the guy who wrote vobsub (smart guy btw) and he told me that (smartripper, dvddecryptor) didn't quite remove all the multi-angles even though i've enabled multi-angle processing in both ripping proggies...that's wut's causing vobsub to screw up when adding subs..so...
i'm just wondering if anyone watched a ripped version of the movie and can confirm that dvddecrptor and/or smartripper can completely remove multi-angles from this movie (should i use cladDVD???)???
Results 1 to 11 of 11
Yup, I can guarntee you it worked smoothly, as i've done this movie myself using Smart Ripper, I had the US NTSC version.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
In case it helps, I've ripped the PAL version with VCD Galaxy, no problems at all.
poopyhead, yes I did, which part did you have problems with ?
Best Regards,
Sefy Levy,
o...i actually haven't encoded it yet because i couldn't add the subs...however, i had the writer of vobsub take a look at my .idx file and he said some of the vob id's were repeating, which meant that there are repeating loops in the movie...
Interesting, I haven't seen any repeating, i'll check the movie again to see if I accidently missed any (movie is so boring!).
Best Regards,
Sefy Levy,
yeah... sure.. if you want your date to flunk cause you fell asleep during the movie
Well, I checked the movie and no problems with my rip, what exactly, or should I say, where exactly did you encounter problems ?
Best Regards,
Sefy Levy,
basically, i add subs to rips using vdub/vobsub method...and the first time this screwed up....
after vob sub finished indexing the vobs, it gave me an error msg saying unable to parse index (.idx file i assume) line 118 reindexing...and this continues till infinity...basically the author of vobsub told me it's cuz the vobs have multi-angle somewhere in them..but i used both smartripper and dvddreyptor w/ multi-angle processing enabled and both gave same results.....should i try cladDVD?...however, i've had probs with cladDVD before when ripping movies with multi-angles (i.e. T2 ultimate edition)..but i guess i have no choice.... -
Since you want subs, why don't you just use DVDx or FlaskMPEG ?
Best Regards,
Sefy Levy,
Diary of a newbie FFmpeg learn to help others! convert to High quality!
By gugaoforums in forum Video ConversionReplies: 6Last Post: 10th Sep 2011, 03:07 -
My Travel Diary–2011 PowerDirector Video Contest
By sog328 in forum EditingReplies: 4Last Post: 13th Jul 2011, 18:03 -
Software to Record Voice/Audio. Diary!
By UmmAddan in forum AudioReplies: 4Last Post: 28th Jun 2008, 20:43 -
Indiana Jones and The Kingdom Of The Crystal Skull
By Epicurus8a in forum Off topicReplies: 53Last Post: 2nd Jun 2008, 17:19 -
Indiana Jones 4 title....
By j1d10t in forum Off topicReplies: 4Last Post: 10th Sep 2007, 18:54
